calling all wattage gurus. So new to me but maybe a issue, you shouldn't use latex tubes with carbon clinchers because of heat build up on the brake tract. I have 3 sets of carbon wheels but i can handle just having one set for mountain trips with descents. My question is which non-latex tube will save me the most amount watts with the fear of heat issues ?.........thanks for any and all advice
Re: best non latex tubes [bikeman12-1]
bikeman12-1 wrote:
calling all wattage gurus. So new to me but maybe a issue, you shouldn't use latex tubes with carbon clinchers because of heat build up on the brake tract. I have 3 sets of carbon wheels but i can handle just having one set for mountain trips with descents. My question is which non-latex tube will save me the most amount watts with the fear of heat issues ?.........thanks for any and all advicehttps://www.aero-coach.co.uk/...e-rolling-resistance
I use latex tubes on my carbon clinchers every day.
Re: best non latex tubes [jimatbeyond]
jimatbeyond wrote:
I use latex tubes on my carbon clinchers every day.Benjamin Deal - Professional - Instagram - TriRig - Lodi Cyclery
Deals on Wheels - Results, schedule, videos, sponsors
Re: best non latex tubes [SummitAK]
awesome, thank you
Maybe you should change to butyl rubber tubes when you know that you will be using your brakes on steep descents.
bikeman12-1 wrote:
calling all wattage gurus. So new to me but maybe a issue, you shouldn't use latex tubes with carbon clinchers because of heat build up on the brake tract. I have 3 sets of carbon wheels but i can handle just having one set for mountain trips with descents. My question is which non-latex tube will save me the most amount watts with the fear of heat issues ?.........thanks for any and all adviceWhat you are asking is not clear. The best butyl tubes for racing IMHO would be Conti Race Light tubes. Are there faster tubes, which you seem to be implying by "wattage gurus"? Yes but they don't meet a durability/reliability component in my eyes. An example would be Conti Supersonic. I would never recommend this tube no would I personally ride it. You fears of latex are overly irrational. Likely because companies do and say things for liability reasons.
If you do want non latex tubes after reading all of the above post's. I'd suggest Panaracer. Made in Japan, thin, light, and very high quality.
Re: best non latex tubes [Thomas Gerlach]
Thomas Gerlach wrote:
Yes, you are unlikely to have an issue if you are careful with your rim tape, and if you are a light rider, and if you avoid dragging your brakes on descents. I'm a fairly heavy rider (~84kg), I don't want to worry about my rim tape, and while I descent fairly fast and don't think I drag the brakes much, I don't want to take any unnecessary chances, even pretty small ones.
Re: best non latex tubes [Ai_1]
I think you nailed what I was trying to get at...I spend 99.9% of my time riding hills and flat group rides but occasionally I do enjoy a trip to the mountains. Some of the descents can last over 20 mins...that’s where the fear of latex was involved....thank you all for your advice
https://www.strava.com/segments/4661416
this segment is my biggest concern....for the more seasoned roadie they may say its short enough not to worry but it has a fair about of speed "for me anyways"....40mph with some hard braking. If you guys dont think its enough to worry over i would love to run latex all the time....thanks
I like continental race light tubes.
the world's still turning? >>>>>>> the world's still turning
bikeman12-1 wrote:
https://www.strava.com/segments/4661416 this segment is my biggest concern....for the more seasoned roadie they may say its short enough not to worry but it has a fair about of speed "for me anyways"....40mph with some hard braking. If you guys dont think its enough to worry over i would love to run latex all the time....thanks
Re: best non latex tubes [realbdeal]
realbdeal wrote:
Despite being pretty steep, that segment shouldn't actually require too much braking as it's fairly straight. It's switchbacks and super windy descents that are going to require serious braking. In Albuquerque, the longest descent we had was this one: Sandia Crest Descent. Note the switchbacks on the top half of that, which is also the steeper section. At ~170lbs, I've descended that on my tri bike and road bike, both with rim brakes, carbon clinchers, and latex tubes, with zero issues. You'll be fine on that segment with latex.
jimatbeyond wrote:
I use latex tubes on my carbon clinchers every day.Surprised that you don't know that not all carbon clinchers are equal when it comes to heat-dissipation upon braking?
Plus some riders out there just can't let go off the brakes for even a short time (see, actually smell it quite often).
Count me in on the Continental Race Lights.
windschatten: Dec 16, 20 16:49
Re: best non latex tubes [windschatten]
OP said that they sometimes ride steep descents.
Wouldn't it be smart to use latex tubes most of the time and then switch to butyl rubber tubes when riding the steep stuff?
Re: best non latex tubes [MrB]
MrB wrote:
If you do want non latex tubes after reading all of the above post's. I'd suggest Panaracer. Made in Japan, thin, light, and very high quality.Interesting. The panaracer website says their tube has twice the elasticity of standard butyl. Is there any RR data on that tube?
Edit: Nvm, BRR tested is as equal to Conti 28 Light. Do you find it supple like latex?
Re: best non latex tubes [BigBoyND]
Did you look at Schwalbe Aerothan? They are almost as fast as latex but heat resistant and are claimed to be puncture resistant as well. Look at the link to the AeroCoach website in one of the earlier replies where you can see how they performed in tests.
Yes, I plan to order some for my spare kits and maybe replace my latex tires with them as I get punctures. I'll pay the 1.5W for the pair so I can pump my tires every other ride instead of every single one.
