The consensus I have seen tends to be that they are pretty similar in a straight flst line, but the jet 9 edges outbthe H3+ when there are more crosswinds or hills.
So basically the h3+ would perform best on flat straight stages but the jet 9 stands out with hillier, windier courses.
That said, you won’t go wrong with either, and if the h3+ gets you pumped to ride cause it looks so damn good you may well eek out a watt or two more and perform better anyways.
