Hello DarkSpeedWorks and All, https://view-speed.com/store
Sold several hundred skewers ... very few complaints ... very aero ... aircraft grade 5 Ti solid shaft
Axial failure test by Element Testing 3,681 pounds .... at skewer thread. S4 and S3 skewers had very similar numbers.
Element Materials Technology
Huntington Beach, CA
MIL STD 1312-8A/NASM 1312-8 (1)
You could hang a small car from one View-Speed Skewer ...
Used World Championships for track racing.
Patented D742777 and D742297
View-Speed Inc.
Skewer Installation Instructions
1. Remove your old skewer.
2. Insert your new View-Speed Inc. skewer.
3. Loctite has been applied to the skewer threads … ready to install.
4. Tighten skewer then loosen skewer so you know it will come off easily if you flat … retighten to 4 or 5 NM … good for several on and off cycles without more Loctite.
5. The keyed part of the nut faces in the open slot of the fork slot or dropout dropout opening.
6. Insure your bicycle wheel is aligned properly and tighten skewer with a 5mm hex key and torque wrench to not exceed 6 NM. Usually 4 or 5 NM is adequate.
7. Check that the skewer threads are fully engaged in the nut so the skewer is either showing 1 thread or the end of the skewer bolt is flush with the outer surface of the nut after cutting off excess skewer.
8. Check that your wheel is secure. (It should not have any play)
The S4 skewer requires ¼ inch (6.35mm) or greater fork or dropout thickness. The S3 skewer fits most forks. You may cut off the excess threaded portion of the skewer flush with the nut keeping in mind that the skewer many not fit another bicycle with a different fork.
9. Before a race be sure to loosen your skewer and re-secure it to be sure you can operate it easily and quickly.
10. If you have questions please visit our website
www.view-speed.com for more information.
20160120
View-Speed Inc. Guarantee and Warranty
100% Satisfaction Guarantee
View-Speed Inc. offers a 100% satisfaction guarantee on anything you buy from our website.
If you are not satisfied with one of our products at the time you receive it, or if one of our products does not perform to your satisfaction within 25 days of the purchase date, return it for a replacement, or a refund.
Anything you buy from one of our authorized retailers is guaranteed through the retailer. All exchanges and refunds must be done through the retailer where purchased. The retailer may have a different guarantee policy than the View-Speed website guarantee policy.
Cheers, Neal
+1 mph Faster
