I am positive that we talked about this multiple times in the past but I cannot locate the thread. Can you fit a super 9 clincher on the old Cervelo p3c or does it need to be a 900?
Re: Zipp super 9 disc on Cervelo p3c [Fishbum]
Re: Zipp super 9 disc on Cervelo p3c [philg]
Soooooo maybe
I previously owned a 2012 P3 and used the Super 9 disc with no issues.
In 2017 Zipp released the Super 9 for disc brakes, but it still had the rim brake layup. (Note that the surface of the rim brake track was not textured, but smooth/gloss carbon.)
I used that version of the wheel on a 2008 P3C using rim brakes. (I've got that wheel on Craigslist for $1200 if anyone is interested and local (Colorado). I don't want to ship it.)
2015 USAT Long Course National Champion (M50-54)
Re: Zipp super 9 disc on Cervelo p3c [Paul Dunn]
And I take it there were no issues.
Correct - no issues. (Other than you do need the correct end caps. The wheel comes with end caps for thru axle and QR.)
Fishbum wrote:
I am positive that we talked about this multiple times in the past but I cannot locate the thread. Can you fit a super 9 clincher on the old Cervelo p3c or does it need to be a 900?Have a P3C with the Super 9 Clincher, no issues, fits fine.
Best used with something like a 23mm GP5000/4000, a 25mm will be tight and may rub.
But no issues with rim clearance.
Re: Zipp super 9 disc on Cervelo p3c [moonmonkey02]
x2. I own both - you will need a 23mm tire, 25 rubbed on my frame.
Now what’s the fastest front wheel for the P3c 🤔
Re: Zipp super 9 disc on Cervelo p3c [IamSpartacus]
23 conti? I no they blow up bigger than that. Or would you need a true 23
I put a 23 conti on there and it fits fine. So maybe a true 25mm is ok if that’s what it it ends up being. A 25 conti was a no go though
I guess the takeaway from this is that it should fit? Ironically, I've had the same question for days now as well (Black Friday sale). I've got a 2012 P3 frame, but found a great deal for a super 9. Fingers crossed it fits.
