Post deleted by johnthesavage
Re: Help old guy set up trainer? [johnthesavage] [ In reply to ]
You will get a lot of recommendations, but my advice is to keep it simple. I have the below 'smart' trainer, and it is perfect for my needs. I ride with Zwift, and it works seamlessly with that on my ipad. I suggest putting a cadence meter on one crank as well, and then get a simple riser block for your front wheel. That's it!
There seems to be a newer edition, but this is the one I have and I love it:
https://www.kurtkinetic.com/...ock-and-roll-smart-2
I will say that it is rather heavy, but sounds like you won't be moving it around too much. I actually picked mine up slightly used for $200 so browse your local FB and craigslist.
Re: Help old guy set up trainer? [Zissou] [ In reply to ]
Thanks KISS is my motto, I just didn't know where to start. So I'm just going to go with your rec thanks! Can you come by my house and help me set it up? ;)
If you're looking to cut through the crud on the internet, in my opinion you can't really go wrong with reviews, info, and recommendations from DCRainmaker:
https://www.dcrainmaker.com/2020/11/smart-cycle-trainer-recommendations-guide-winter.html/
I replaced a 33+ year old Blackburn Mag Turbo trackstand trainer in the last several weeks with a Tacx Flow. Like you, I believe in the KISS method. There might be a point where I upgrade, but after having a dumb trainer for so long, I needed to start somewhere.
