Are you a 0 or a 6...degree float?
Me? Definitely a 0!
After 35 years of riding the Mavic/Shimano/Look pedal system, I switched systems so that all my bikes are the same. Completely forgot to pick up 0 float cleats, so I will see how my knees are tomorrow after a session in the 6 float.
Re: Are you a 0 or a 6...degree float? [EndlessH2O] [ In reply to ]
There is also a 2 degree float cleat.
I use 0...have for about 6 months now. No real reason, they just work and i like how they feel though it does take a bit more time to get just right
Strava
EndlessH2O wrote:
Me? Definitely a 0!
6 degree.
Swimming Workout of the Day:
Favourite Swim Sets:
15
Open my speedplay zeros ALL the way!
My first pair of cycling cleats had 0 float. I destroyed my achilles as they were not aligned correctly. I now use 6.
6 degrees.
Speedplay Zero pedal/cleat adjusted to give approximately:
15 degree toe-out (max)
5 degree toe-in (to make clip out easier, otherwise I'd leave this max also)
In other words the only reason I want any limit on float is to facilitate clip out.
I don't need the pedal to provide a mechanical limit on foot yaw, my legs are far better at managing this.
I've changed from the grey 4 to the red 9 degree cleats on Look Keo pedals.
My right knee is thanking me for it. (My left knee is ambivalent and was fine with 4 degrees).
Re: Are you a 0 or a 6...degree float? [jimatbeyond] [ In reply to ]
This is what I use : 2 degree float :)
BetterShifting.com - Di2 help and guides| BetterShifting Instagram | Terry's Instagram
I hate the feel of any float. Used 0 float Shimano's for years.
It is really bothersome because while I want to like my Speedplay aero zero's... there is no way to get that locked in feel with them :(
My Blog - http://leegoocrap.blogspot.com
Re: Are you a 0 or a 6...degree float? [Morelock] [ In reply to ]
Do you not get that by closing the adjustment grub screws right down to lock the float? I've never tried myself, perhaps this still leaves perceptible play in the system?
Re: Are you a 0 or a 6...degree float? [Ai_1] [ In reply to ]
yeah, unfortunately just by the design speedplays will always have some float in them, even with the grub screws tightened all the way down. It's probably not measurably a lot, but it feels like your foot is all over the place (comparatively to something like Shimano Reds)
I've always used 0 float except for the time I put the "cool looking" red cleats on and hated them. It takes me some time to get them right but I like the locked in feeling.
On my mountain bike I use eggbeaters with 6° float. I'm indifferent to them because I thought that was the only option available until now. I just looked them up and there's a zero option, I'll be looking for a set of those today.
Re: Are you a 0 or a 6...degree float? [jaretj] [ In reply to ]
I use the gray 4.5 degree Look Keo Cleats with my Assioma power pedals. Give me enough float and work great with the pedals.
6 degree
I use 2 degree (shimano blue) cleats.
To me, the biggest difference in feel from the yellow 6 degree cleat is that the pivot point is in a different spot. Rather than center of the cleat, it pivots closer to your toe. As soon as I tried them, I was sold.
Same. Only adjusted enough to make release comfortable.
"...the street finds its own uses for things"
