2012 cervelo P5 brake help
Hi Slowtwitch. I have an athlete who can't get a resolution with her hydraulic brakes on her P5. Has been to two different LBS, and they can't seem to get em fixed (they keep leaking). Any recommendations on a brake and lever swap?
Thanks in advance.
CB
Physical Therapist/Endurance Coach
http://www.cadencept.net
Re: 2012 cervelo P5 brake help [PTinAZ] [ In reply to ]
Can you be more specific?
P5/6?
If P5/6 Magura is the only answer.
The Magura RT8 &RT6 are hard to find.
Re: 2012 cervelo P5 brake help [Clutch Cargo] [ In reply to ]
Yes, P5 six
Got it....thank you. :-)
CB
Bleeding or leaking?
Re: 2012 cervelo P5 brake help [jimatbeyond] [ In reply to ]
Sorry, I meant leaking. :-)
CB
Ok
Leaking from the leaver? Caliper ?
It’s a simple system lever, hose connection &caliper
It's leaking from the lever. They have taken the system completely apart and replaced the lines but they still leak. Brakes last about a week.
Heya,
I went tririg omega https://www.tririg.com/store.php?c=omegaone and they are a thousand times better.
Re: 2012 cervelo P5 brake help [az] [ In reply to ]
Quite a coincidence when they BOTH leak
check this thread
https://forum.slowtwitch.com/forum/Slowtwitch_Forums_C1/Triathlon_Forum_F1/Magura_RT6_brake_lever_leaking_P6728330/
Re: 2012 cervelo P5 brake help [Smokeythebandit] [ In reply to ]
I’m going through this with my P5-Six right now…Magura brakes completely shot…did the TriRig solution hold up for you?
Re: 2012 cervelo P5 brake help [TRI_ATL] [ In reply to ]
I listed a set of Magura brake levers and calipers for P5-6 (new) for sale in the classifieds.
