I don’t know the dimensions of his wheels but based of pictures, I don’t see any reason why a 42mm or even a 48mm stem wouldn’t work. The opening looks rather long and wide and I would highly doubt you will have any clearance issues. Unless you have an abnormally large crack pipe. The super9 disc has one of the smallest openings to fit a crack pipe in it. I severely doubt the premier is smaller than that.
Also... I don’t think I’ve ever seen a butyl tube with a 35mm stem. It might exist but I would think that’s rare (someone will correct me if I’m wrong). I think you can easily get a 35mm stem for a tubeless setup but that’s another discussion.
Edit: if you have to run butyl on a disc wheel, then that kinda defeats the purpose of a disc.
blog
