Hi all,
I was injured a week ago Sunday and I'm looking for answers as to what happened.
I have a gravel bike, Cannondale Topstone with aluminum, tubeless ready WTB rims. I was riding the bike to our local pool to coach a youth tri group I work with every Sunday, when I took a corner and my rear tire blew out. The tires are 43mm Panaracer GravelKing SK, setup tubeless. I had inflated to 4 bar (60 psi), the max per the tire, and the loud blowout happened while cornering. I went down hard and tore my right MCL as I landed tangled up with the bike. Looks like I'll be in a knee brace for several weeks.
So I've been looking at my tire and rim and I can't figure out what happened. The tires were relatively new, maybe 200 miles on them. They had been fine previously. There was no puncture in the tire or the rim tape that I can see. Did the bead simply pop off the rim?
I know most would say I ran them at too high a pressure. I generally agree in that I usually run them at 40 psi or so and I was in a bit of a rush and inflated higher than usual, plus I usually go higher for road only riding and for the rear. Still, I was not above the max stated pressure for the tire and I would think there would be a bit of a factor of safety against a failure.
Anything else I should look at? I would like to at least learn something from this.
http://www.desotosport.com
http://www.ceepo.com
