Compression plug for carbon fork steerers - which ones do you use?
I tried a few cheapo ones from Amazon - they all suck and can be really really hard to remove. Which ones do you use?
I used to have to a Time bike with a plug that was not an expander but would just fit snugly into the steerer - anyone knows if these are still available somewhere?
Thanks!
Next races on the schedule: lolwut?
Re: Compression plug for carbon fork steerers - which ones do you use? [alex_korr] [ In reply to ]
For reinforcing the fork and everyday use, Specialized. For saving weight, Enve. I tend to stick with the Specialized one.
Re: Compression plug for carbon fork steerers - which ones do you use? [bloodyshogun] [ In reply to ]
The specialized for $10 is by far the best I've used.
I think that every carbon steerer should come with a full length aluminum insert bonded in, though.
This one: https://www.ebay.com/itm/283742624177
Origin8 Compression Plug: Really impressed with the build quality; loads better than the one that came stock with my BMC.
$15 shipped.
Re: Compression plug for carbon fork steerers - which ones do you use? [Titanflexr] [ In reply to ]
ENVE has a good one.
https://www.enve.com/en/products/fork-compression-plug/
I use this Deda because it’s quite long and allows a lot of stem adjustment without worrying about support.
https://www.bicyclehero.com/...a-expander-bung.html
Can never go wrong with Token
Their newest model is ONLY 19 grams.
Honestly, I used to work for Token before Culprit was even a thought. They have an incredible design team the last few years and are really doing well on focused products. namely hubs/wheels and anything to do with headset parts.
Give this a go.
https://www.tokenproducts.com/headsets/accessories/431-push-n-turn-expander
