jimatbeyond wrote:
I have all of the correct tools. Recently, I even got one of my brother's extra Snap-On torque wrenches for installing Rotor cranksets.
I just don't want to see people bringing their bike unnecessarily to a bike shop. You can look around your house and find tools that will work. You don't have to have the correct bike tool when a hammer and piece of wood or a screwdriver can get it done.
Imagine being in a hotel room unpacking your bike before a race. You find a bent or broken part. You don't have the bike tool to fix it so you need to use whatever is handy.
In most cases, a torque wrench isn't necessary. It gives the user a false sense of security and I have seen many people break bolts and components because their torque wrench didn't "click", so they kept applying more force.
When I am teaching someone how to install a cassette, I tell them to feel how the lockring gets notchy as it gets tighter. Generally, about five of those notches (clicks) is properly tight.
I am literally that person you are trying to teach/impress with your 'use basic tools' and don't buy extra stuff so they don't become totally reliant on LBS.
I can say firsthand - as a nonexpert, very infrequent bike repair person, using the BEST and most appropriate and SPECIFIC tools is your single best route to success. Bar none. And even if you order all these specific tools, you will still come out far ahead in terms of cost and time saved compared to LBS or using suboptimal tools.
If you're an expert at the procedure in hand, or have done it so many time you can do it in your sleep, that's the time to start messing with alternative, suboptimal tools. As a rookie fuggetabout it. World's biggest waste of life and time.
Try dialing in an indexed RD without a derailleur hangar adjustment tool. Congrats you just wasted 4 hrs of your life trying to cheap out on it. Buy the tool, spend 1-3 mins straighteningthe hangar, and in most cases you don't even have to touch the barrel adjuster of the RD for perfect shifting.
I actually tried a wrench + rags on my BB before I bought the specific tool for it. Scratched it all up, and got nowhere in the process. Sure, I could have used a BIGGER wrench, but that would have made it worse. Once I had the right tool that fit on the splines perfectly, it was literally trivial to remove it. Tools count. A lot.
