I got a nice pair of high end Giro road shoes. I see a lot of athletes using them these days over tri shoes. What's the secret to getting into them easily when they are already clipped into the pedals and your mounting the bike coming out of T1?
Re: Road shoes for long course? [crujones#33]
Depending on the model you can remove the laces, replace them by elastic ones, and/or cut away the tongue to make them a little more roomy.
https://besse.info/
https://www.strava.com/athletes/2012033
https://besse.info/
Re: Road shoes for long course? [jcbesse]
jcbesse wrote:
Depending on the model you can remove the laces, replace them by elastic ones, and/or cut away the tongue to make them a little more roomy.This.
The aero is great and elastic laces are fine as long as you're not going to sprint or get out of the saddle up a climb like a Tour de France climber trying to crack the lead group.
For two years I used my Sidi Wire road shoes for triathlon.
I put them on in transition and didn't find I lost much.
Re: Road shoes for long course? [NordicSkier]
NordicSkier wrote:
For two years I used my Sidi Wire road shoes for triathlon. I put them on in transition and didn't find I lost much.
This. You're riding for ~5hrs. Even if it costs you 15s in transition, that's pretty minimal in the grand scheme
Cleats do get a bit banged up from running in them though
Re: Road shoes for long course? [indianacyclist]
Speedplay walkable cleats. Not an issue!
Hi all, this is my first post on ST but I thought I’d add that in one of my first sprint races I was wearing speed play cleats and ran on grass from transition to the mount line, in that time I ended up with a small stick stuck in the cleat and was barely able to clip into my pedal. I switched to keos soon there after when I got my assiomas.
Re: Road shoes for long course? [TrainBrain]
TrainBrain wrote:
Hi all, this is my first post on ST but I thought I’d add that in one of my first sprint races I was wearing speed play cleats and ran on grass from transition to the mount line, in that time I ended up with a small stick stuck in the cleat and was barely able to clip into my pedal. I switched to keos soon there after when I got my assiomas.Speedplay cleats clog fairly easily. For muddy T1s I usually carry the cleats past the mount line then put them on at roadside. You can run faster barefoot anyway.
ECMGN Therapy Silicon Valley:
Maybe you know the OP but he/she could be doing sprint races and is on the bike for 30 min
Re: Road shoes for long course? [Titanflexr]
Gotta get Speedplay Zero Pave.
Re: Road shoes for long course? [jaretj]
The title of this post is literally “Road shoes for long course?”
The two hangups are typically the tongue getting pushed forward as you insert your foot (I've actually removed the tongue from my lace-up, flying mount shoes....viability depends on your closure system), and getting your heel to slide in (bodyglide on the heel counter helps).
Practice is key, but (as I found out race day) getting into the shoes with dry socks on is very different than with wet feet. Practice barefoot.
Yep it is...zoomed right by me (literally)
Either run barefoot and put your shoes on right before you get on the bike which only takes seconds or put the caps on your cleats....assuming you have the walkable cleats.......and pop them off before you clip in. You can keep the caps in a pocket or toss them.
crujones#33 wrote:
I got a nice pair of high end Giro road shoes. I see a lot of athletes using them these days over tri shoes. What's the secret to getting into them easily when they are already clipped into the pedals and your mounting the bike coming out of T1?Most athletes should be using them for the aerodynamics first. But yes, I got this trend going many moons ago when I wrote and wind tested Giro SLX with elastic laces. Of course elastic is no more secure than other closure mechanism, but definitely allows for very quick entry and exit. When I developed this idea for myself, although, I did later find out that a few pros way back in the day used elastic as well. Regardless It was a benefit to me as in pro races the first 3-5 minutes of the bike and transition is a gong show, and anytime saved means you are missing a surge or two which helps for the rest of the race.
If it's a long course I wouldn't worry too much about the time lost if they are that much more comfortable than tri shoes...
101Ironman Hacks & Newsletter: http://ironmanhacks.com/newsletter/
YouTube interviews with legends like Mark Allen, Dave Scott, many more: https://www.youtube.com/...s?sub_confirmation=1
Re: Road shoes for long course? [Patterson]
First off, your username is RAD! I’d say all these ideas are good you just need to find which one works best and saves you the most time. You can get cleat covers for look style cleats which help with running but then I guess you need to carry them or toss them.
Wow, you just opened my world up to new possibilities. I had assumed that elastic laces on bike shoes would compromise power but reading this and other posts, and the fact that I never actually researched that idea... makes me realize I should do the same. Currently, I use boas and I feel it takes me some time to tighten them to where I like them to be, while that doesn't matter much in an IM, it matters in a 70.3. Especially the two 70.3s last year that I could have been one place higher by saving 5 seconds!
808 > NYC > PDX > YVR
2024 Races: Taupo
