Apologies if this has been answered before but...
If I use the Silca tire pressure calculator, the tire pressure I need to run for optimum rolling resistance is much lower than what would historically be recommended. E.g. If I use 25mm tires, then measurement is more like 28mm wide when inflated. Based on a truely accurate weight of rider and gear (bike, bike shoes, helmet, drink bottles etc etc), then the recommended PSI for my scenario is in the low 70s. So my question is, when the PSI is run so low, do the benefits of latex inner tubes still hold up? Or is it reduced as the tire pressure is reduced so low?
