brasch wrote:
My point is, wether you like 155 or 165 cranks is probably a matter of individual preferences.Yep. Absolutely. And, changing crank length dramatically probably is best done with the help of a fitter. Becuase, if everything isn't adjusted right...then, yeah it feels exactly like you described. My Road boke is 175mm, TT 150mm. Once I got the TT bike fitted properly, I couldn't tell the difference between them. YMMV, of course.
brasch wrote:
Aside from that, it’s worth noting that when changing crank length, you’re effectively changing the gearing as well.Yep. It's ~1 cog per 10mm change in length. All else staying the same. More or less.
