Have you ridden the new Zipps?
Anybody try the new 303 or 303S tubeless wheels? Did you do it with the 28 mm tires they recommend at 60 psi? There was a big marketing surge when introduced, but delays in moving the product.
Re: Have you ridden the new Zipps? [Waingro] [ In reply to ]
I have a set of 303S wheels. I'm running a 25mm tire which measures 28mm when inflated, the Schwalbe Pro One (HS493). I've been riding them since July and have about 900 miles on them. I'm running about 70 psi and they smooth out our chip seal quite well. Overall, I'm pleased with the purchase.
im pretty sure it was the 303S model that jordan rapp (rappstar) posted on instagram saying he was able to run them consistently below 40 lbs with what im thinking was a gravel setup. that def got my attention... when the budget allows they will probably be my daily ridden wheels.
'21 Captex Tri / Lubbock 70.3 / IM Cozumel
