gregf83 wrote:
mattsurf wrote:
The law of conservation of energy, all of the kinetic energy from the bike is transfered to heat. some of the heat is transfered to the rims, and some of the heat to the pads, therefore, a brake pad that heats up less is either less effective, or is better a dissipating the heatNot a physicist here, but does this aero drag really burn off that much heat for a bike rider descending like at 25mph vs 15mph? To the point that it will save that much heat?
I could speculate the converse 'extreme' case - that braking hard all the time (in a ridiculous way) might the safest, lowest temp way to go. Like. if you go do the Alpe de huez at a measly 5mph - the whole way down. I'll bet in that case the heat generated will be so low that you will never come close to blowing out a rim?
