devashish_paul wrote:
Watching the Alaphilippe debacle, the drill in action, the inability to change the wheel in a meaningful time frame, and subsequently the discusison on various threads here on ST, it seems like disc wheel as a tool for pro tour racing during a failure situation is probably not the optimal tool for the job. When the bike is working fine and there is no need for a wheel change, fine, we can debate rim vs disc till we are blue in the face. But in a failure situation, it seems like the ability to get back on the road and compete, is hurt by disc vs. rim. Minimally the Mavic neutral support only carries rim brakes, so you are stuck waiting and hoping your team car is nearby for your spare bike or the drill working and quickly being able to change the disk brake wheel.
I would see it rather differently.
- mechanic failure - he/ she botched the wheel change ?
- maybe didn't check the tools (drill) worked with the set ups the team had - obviously not well enough anyway, unless there was something V wrong like the axle had cracked and jammed or something (or maybe someone fecked up the installation and cross threaded it and used a drill on max torque to get it to seat ?)
- shite detail design by some bike Cos. The through axles do not have to be a hex socket head. They don't for a tiny aero fain and aesthetics.
No reason why the axle can't have a Lever on it to turn - in fact MTB through axles (Maxles and the Fox-developed 15mm front axle) has a QR style lever as well as threading through.
Through axles - those and discs do not have to be coincident. Mountain bikes used standard QR for over a decade with disc brakes (bigger than road discs too) before the bike industry decided to shift to through axles - but not specifically for discs and braking but for increased torsional stiffness for the 95% of the time not braking - so the bike actually goes where you point it. Front and back. Just as they have now gone to Boost hub spacings. QR on Mtbs never caused alignment problems on discs.
