Dapper Dan wrote:
If I'm patching I can usually just slide out a section of tube rather than remove the whole thing. This means I may not need to remove the wheel from the bike.
This is a big deal, and I'm blown away at how little folks talk about it these days, and how few seasoned cyclists do it in modern times, or even realize it can be done. When I get a flat, I stop immediately, and look for the cause. Around here, its usually a goathead, or often thorns/nails/screws/glass... and even one time it was a fish hook. And 9 times out of 10, the offender is still stuck in the tire. I even carry a sharpie for this. I will draw a line on the side wall of the tire, where the object is. Then remove the object. Then use a tire lever to pop just enough bead of the tire off, to pull the tube out. I'll reference the line on the tire, to find the hole in the tube. Patch it. Then pop the tube back in and the bead back on, air up, and go. I learned this over 40 years ago, when I got into club racing and weekend centuries. That was before kevlar tires, and we got good at it. The only time I take a wheel off, out on the road, is when I can't locate the cause of the puncture.
Athlinks / Strava
