JSA wrote:
Finished the interior. The door kinda sucked. I removed the panels. There is a piece of trim at the top of each door. It is metal with hidden nuts. You have to reach inside the door and fish around to find them. Then, peeled off the old leather. Removed all the rust with the Dremel. Cut the leather using the old piece as a template and replaced. The adhesive spray has to sit for 5 minutes before application. So, I had to spray the underside edge, wait, affix, hold, dry. Then spray the main area, wait, affix, hold, dry. Then do it again on the other side under-edge.
I removed all the screws and, for the visible screws, used the Dremel to polish them.
Replaced all the seals - window, door, boot, windshield. Replaced the visors.
I initially installed the seats and then could not get them to move. For some reason, they would not slide on the rails. Finally figured out the new rails had sharp edges that were getting wedged in the track. So, I removed the seats and pulled out the rails again. Used the Dremel with a metal shaver to cut them down, then course sand, then fine sand, then polish. Finally worked.
So, she is put together, but, the taillights don't work. So, I pulled out the wire. Dammit ... I'll fix that this week, then decide whether to take on the exterior now or next season.
Very nice, you must have a lot of vacation.
_____
TEAM HD
Each day is what you make of it so make it the best day possible.
