Let's just say hypothetically that I want to try to approximate my TT position on either an endurance road bike or a gravel bike (and let's not debate "why"). Case in point: my TT bike is a Speed Concept and I'm eyeing either a Trek Domane or a 3T Exploro Race Max. I've put a geometry comparison chart below. For the sake of discussion let's just say that I can get within 1cm of the appropriate stack/reach on either of those bikes using a long, negative stem. My concern would be handling and weight distribution. Let's also assume my saddle is in the same position relative to the bottom bracket (feasible as I actually had to push my Adamo Prologue *back* and I still have that saddle around).
For my Speed Concept in size "large" I have a front center of 623 which is within spitting distance of the Race Max at 621. I can't find a Front Center for the new Domane SLR but I'm guessing it's somewhere in the range of 600-610. So here's my question: would a 120mm, -17 stem on something like the Exploro or the Domane put too much of my weight forward? (let's also assume that I'm pretty well centered on my current TT bike). It appears with a 120mm -17 and a *very* low stack bar I could nearly hit my pad XY on either bike. However... if I'm thinking about this correctly, the Exploro would handle a bit slower due to the slightly longer wheelbase. The Domane would have the same wheelbase but my center of gravity would be a bit further forward. Correct?
GreenPlease: Jul 29, 20 16:32
