hopefully this will "fix" some of the problems that already exist in zwift duathlon. As of right now, racers start the bike at different times (based on how long it took for the first run) and in different ability categories (A-D or sometimes A-E) Then they start the final run at a earlier predetermined time. so you have to guess when you will likely finish the bike so that you have enough time to make the start time of the final run (because it is a pre-establisted zwift event with a specific start time). Can be a real headache for some people, especially with connection and software issues abound. in the end the results are calculated, so it takes a day or so to know the winner. you're not really racing head to head. To do this right, the super league athletes must be in the same zwift event "race" but starting at different times. kind of like the "late join" function, but you must start at the start line and do the full distance, not join up with riders already moving. i realize this is a little hard to follow, but if you've done a zwift Du you'll know what i mean. this is a chance to change the programming to make it a more realistic, head to head event.
