New bike stuff needed - Tiagra vs 105 vs Ultegra
I am in the market of new stuff for the bike and I need some advise. I am looking to buy a 10 speed cassette, chain and crankset + chainrings
For the cranks and crankset I am looking at the 105 fc-r7000 It is for 11 speed but should work with a 10 speed setup, right?
Chain - Ultegra CN6701 (or even Tiagra CN-4601)
Cassette - is where I'm not sure what to do, I am considering the Tiagra cs-hg500 because of the price but I have never had Tiagra before, is it as good as ultegra? I am currently not interested about the weight but rather on the quality of it, will it wear faster than ultegra? or any consideration I should take?
I want to spend as little as possible but without wasting money on something that will not last, in that case I am willing to spend a bit more. Will this combination of 105 crankset/Ultegra chain/Tiagra cassette work fine?
Re: New bike stuff needed - Tiagra vs 105 vs Ultegra [JorgeRamos] [ In reply to ]
Why not go with 11 speed?
Personally I find the shifting quality on 105 Lackluster vs ultegra. I’d personally spend the little bit more on ultegra
If you’re buying the entire group set I would go 11 speed unless there’s a significant price difference. Nothing wrong with 10 speed though. I have 105 on all my bikes and have zero issues. On my road bike I previously had tiagra and it was fine. 105 definitely shifts better but I had no issues with tiagra. Honestly any of the shimano stuff will last.
Re: New bike stuff needed - Tiagra vs 105 vs Ultegra [mvenneta] [ In reply to ]
probably because he is already running 10s shifters and derailleurs, and possibly older wheels that are not 11s compatible.
Swimming Workout of the Day:
Favourite Swim Sets:
Tiagra will be fine for the cassette* It will be a little heavier than ultegra, but the ramps and all of that stuff is the same.
* if your wheels have an aluminum cassette body instead of steel, go with ultegra. the cog carrier will spread the load and prevent pitting.
For chains, I always go with ultegra (or the SRAM equivalent, but I think ultegra shifts a little better)
Tbh, if I was blind folded, I probably couldnt tell the difference between tiagra and ultegra. All of them work - aside from marginal gains on weight, there’s not much difference, if any from 105 over ultegra to dura ace. If anything, the cheaper groupsets last longer. Unless you have 10-speed now, i’d go with 105, again, unless you want di2, then ultegra, the current 105 groupset is great. I would be cautious about 10-speed tiagra, mainly because the next version is likely to be 11-speed and would probably be compatible with older (and newer) ultegra/dura ace parts, which means more to choose from. And secondly because all shimano 10-speed parts arent compatible.
Aside from weight and bling, there’s no reason not to choose 105. Although, if your wheels are old, they might not be 11-speed compatible
Never had Tiagra before, but don't see any issues. My take on is that the Tiagra chain and cassette would be a bit heavier than ultegra but can't think of any shifting quality issues. What do you have for shifters and derailleurs? In my view, this would have a higher impact on the overall groupset performance.
I recently put 10sp Tiagra on one of my bikes, since I wanted to keep 10sp compatibility with my 10sp DA on my TT bike.
Tiagra shifts fine - the main thing I noticed is that it corrodes fairly quickly - mine is all scarred up with sweat and water corrosion with rusting bolt tops with only 1.5 yrs of not so heavy use.
In contrast, my cold-forged TT bike DA parts are totally shiny after 10 years with no corrosion. (A few scratches from trauma, but that's it.)
Never thought I'd notice that cold-forged DA effect when I got it, but here I am, admitting it's real.
I have used tiagra, 105, ultegra, and now Dura-Ace Di2...
We're not going to talk about Di2 because that's not even close.
Yes, there is undoubtedly a discernible difference between the levels. I have a tiagra long-cage rear derailleur put on my bike for a trip I took to Colorado years ago. I couldn't wait to take it off. 105 is definitely good, and shifts perfectly fine when dialed in, but I have Ultegra on my CAADX right now and despite it being a 2014, it still shifts effortlessly, moreso the FD... the FD on my 105 took a lot of effort to shift, the Ultegra FD shifts very easily and requires not much effort. But this could also be influenced by the cables
@floathammerholdon | @partners_in_tri
Road bike or TT bike? Mechanical or 1st-gen Di2? What gear range are you looking at?
There are other options besides Shimano. I have had good luck with a SRAM PG1070 cassette paired with Tiagra 4700 RD. I really like the cog selection in their 12-28.
I'm currently running a Miche 13-26. Now that I have the right derailleur for it (SS vs the GS that was originally on the bike), I love it. BTW, I find Tiaga SS to be much crisper shifting than GS.
Re: New bike stuff needed - Tiagra vs 105 vs Ultegra [lightheir] [ In reply to ]
Can you offer any thoughts on the ergonomics of the Tiagra 4700 shifters? Particularly, do they fit and feel at all like 11 speed 105 and Ultegra? I have SRAM Force 10 speed shifters and really dislike the fit and feel. Thanks. David K
