Trauma wrote:
Cut the distractions and focus on where you're running... If you listen to music while you run, and have issues biffing regularly, cut the music... There are some great suggestions in this thread, physio to correct imbalances (or poor balance), hill running and bounding drills to help with shuffling (throw in common running drills like A's and B's emphasizing the toe up position in the drills) and prevent tripping...
But generally the equation of success vs. peril works out to an equation of skill/technical demand. Effectively, if your level of skill exceeds the technical demand of the trail, you should be successful, if the technical demands exceed your skill, you're more likely to leave some flesh on the trails... There are plenty of factors that influence this:
- Distraction (not focusing on the 10-20m ahead of you, either due to music, not being present in the moment, etc.) tends to lower your effective skill level, the more distracted you are, the less skilled your performance becomes
- Speed: this one impacts both sides of the equation, speed can make technical elements more demanding, requiring a higher skill level, also, you need to practice your technical skills at a variety of speeds, in order to be comfortable executing them at higher speeds without losing control (or even lower speeds, some technical descending is more forgiving at higher speeds). You can help balance the equation by slowing down through elements at the upper end of your skill level, in order to make them more navigable... Unfortunately you tend to learn this balance through trial and error...
- Conditions: This tends to impact the technical demands side of the equation, rain, snow, extreme dry, wind, etc. can all impact trails (or even roads) and make it more demanding. Time of day can impact some surfaces too, depending on how many people have been through to pack stuff down, or chew things up... A nice grassy path can transition into a muddy trail without mother nature's intervention, through people using the trail before you...
- Visibility: Fog, shadows, and low light (or high light, i.e. sun in the eyes) conditions can impact your ability to see obstacles or perceive depth, which increases the technical demand (unless you have run that trail so much that you know every root and dip and could run it with your eyes closed). Carrying a headlamp (even if it's the middle of the day, if you are venturing into deep bush, or caves, etc. or if there's a chance that you're going to get into twilight hours) can help, or running at better visibility times of day.
- Fatigue/injury both of these tend to decrease your skill level (or rather your ability to execute the skills). Elements on a trail that are easy 5km into a run, might be much harder a couple of hours later as you fatigue), similarly injuries can impact things such as strength and range of motion that can be critical in the execution of technical elements of a trail.
In order to improve the skill side, you need to gradually push above your skill level and try more challenging elements, or different lines, etc. to start to push the boundaries of the comfort zone... But generally if you think about that when you approach trails, you at least have the information available to help balance the equation (either through route selection, gear, or modulating speed). Incidentally, the same principles apply in cycling, speed being a critical element there...
Really helpful - thank you for the thoughtful post
