burnthesheep wrote:
jimatbeyond wrote:
"Regarding the brake cables, the mechanic stated that the two brake cables that I had installed were actually shifter cables, which I have a hard time believing. I've replaced brake cables a dozen times and can easily identify brake cables from shifter cables."
Do you believe what the mechanic said?
I want to know how anybody can ram a brake cable into a shift housing. The diameters aren't exactly such that a brake cable shoved into a shift housing would "slide right in".
A shift cable is visibly a lot smaller diameter than a brake cable is. One is stopping you and saving your life, the other just changes the gears and has no real forces on it.
Also, the ends on a brake cable and shift cable are totally different. They wouldn't even fit or work in the opposing "stops" in the shifter/brake end of things.
So, something one way or another isn't right here.
Incorrect. Vision brake cables, used in base bar brake levers, have the identical end as shifter cables. They paint the end red so you can tell the difference. Also, the tolerances of cable to housing is quite large, and yes indeed, the Vision brake cable, will slide right into a shifter cable housing. I’m not sure how well they would work in a brifter, as I’ve never done it, but they work fantastic in bar end and down tube shifters, I know, because I’ve done it. Simply because their added thickness gives more precise shifting, and possible longevity. Several years ago, I bought a bulk of Vision brake cables, discovered their interchangeability, and have been using them as heavy duty shift cables ever since.
That said however, I think you’ve got the OP backwards. He didn’t use brake cables for shifters... the LBS accused him of using shift cables for brakes. Since the ends are identical, I can see the possibility of this mistake, but with the thickness of the cables, it would be hard to miss. Either the OP really did I this, or the LBS, seeing the possibility, lied about it, to cover up for something, justify the time spent jacking around, or simply wanted to see what they could get away with, inflating the price. Personally, I would request the old cables back... solve that one right there.
Athlinks / Strava
