Tom A. wrote:
BobAjobb wrote:
And in the rain it doesn't take 1 or 2 revs of the wheel to get braking actually doing something with discs.
Ummm...it actually still does in a good rainstorm. I laughed the first time I rode my disc-equipped bike in the rain and there was still that "oh shit, nothing's happening" moment when the brakes are first applied. These aren't automotive discs that are designed for the pads to be in contact while moving. Another myth about disc brakes that's part of the "common lore" :-/
This may be a bit of a hijack of the current thread, but when the OP posted his question I started wondering if one of the real advantages for a disc setup will be an improvement in both aerodynamics and Crr from using a hookless rim like the new 303s. I don’t think you can make a similar rim with a bead hook that will survive the heat issues from braking and compression of the rim wall. In theory, the hookless rim could allow for a net reduction in the watts/mph with the comfort of a wider tire. This sort of fits with either Vroomen or White’s point that removing the brake from the fork crown allows for a more aerodynamic head-tube/down-tube design that offsets the losses from the rotor and caliper.
Personally it hate disc brakes more than just about anyone, but I can see the writing on the wall for rim brakes. We might be at a point where the advantages of disc brakes really do outweigh the PITA factor.
