I knew better, but tried to do a quick adjust and rotated the adjustment screw too far into the brake lever that controls the width of the calipers. Does anybody have a fix for this?
Re: Magura RT8 TT set screw repair? [TPerry]
Can you pop the lever open still with the little clip underneath? if so then the screw will just fall out - you can then thread it back in with an Allen key through the front - it's a bit go a fiddle.
if you cross thread it you have to buy a new lever and that's a pain to fit.
Re: Magura RT8 TT set screw repair? [esuuv]
Thanks!
Turns out the little screw is still there and while I can twist it counterclockwise to pull it out it will not back out. There is now a shinny silver horizontal "bushing" that has moved in front of and just below the adjustment screw. Any thoughts?
