Ryanppax wrote:
The last few days I've been doing sweat rate testing and learning a lot. 2 days ago
4x12 workout @96-99% FTP
Starting weight: 153.7
Ending weight: 151.3
Fluid intake : 2
Total fluid loss: 4.4 (I also peed)
3mi Brick run at Oly pace
Fluid Intake: 0.8
Ending weight : 150
Yesterday
82 min run 92F temperature in the format of 5mi E, 3x1.75 T, 1E
Starting weight 152.9
Fluid intake 3.25
Ending Weight 148
Total Fluid Loss of 8.1 lbs which blew my mind
Woke up today weighing 150lbs. Still under hydrated or low glycogen Im assuming. Maybe both This has me wondering if there would be any training benefit to go into a workout under hydrated. As when we go into an Ironman there's no way to maintain your weight 100% as you would probably go
hyponatremic and consuming that much fluid would be a massive undertaking. I'm seeing data that 6% would be an acceptable loss, and a marathon winnner ended with 10% loss.
So my line of thinking is that by going into a workout somewhat depleted we are able to train for that second half of the race Am I crazy and over complicating things? I think the issue is the synergies between heat adaptation/response and hydration dynamics. We look at heat acclimatization and see its effect on numerous systems and certainly many influencing our abilities to "endure" in heat through adaptation of our sweat efficiency, core temp, bloodshunting, plasma... all of these arguably have a fluid balance component so its presence (hydration) for heat adaptation seems pretty critical ex: we know heat stress - heat stroke symptoms are exacerbated by dehydration. Doubling down on heat and dehydration usually means a trip to the ER, but perhaps there is more to it?
You have stumbled on a yet to be studied (to my knowledge) adaptation from dehydration independent of heat. It is a tough study to pull off as you would want to control for heat and vary hydration state to weed out specific effects. In the name of science it is useful, its value to endurance sport would be a a much bigger question. Maybe it would mimic heat acclimatization to a degree and be another way to approach a "hot race" without turning on the heater or wearing a Parka on the trainer;)
Ex: Have the fan blowing and AC on just make sure you are a few quarts low on fluid and let her rip, but not too low (pink for now).
Maybe some different mechanisms, however, it would need a lot of study to bring it into some practical deployment (if it shows some value of course). Interesting idea at the very least.
Cheers!
