Quote:
Having been a competitive single sport athlete at both; definitely stronger biker than runner. That being said, Garmin estimates my VO2max to be 8pts higher in cycling than running.....but my FTP running is over 20% higher (in Watts....based on my 4iii bike PM and my Stryd running PM).
I've found that the Garmin VO2max calc fails to take environmental conditions into account. Every time there is a warm day, Garmin drops my VO2max 1-2points (since it sees a higher HR for the same ave. Watts). A ride on a cool day, and it jumps back up. I have to check it the next time I'm at altitude to see if the same thing happens. My Fenix5 has both temp and alt, so you'd think they would adjust for this, but that's not my experience.
I've been observing the same issue wrt Vo2max and higher temperatures, however mainly on the run (with Garmin 945). Couple weeks ago during a local heat-wave, I noticed my Vo2max dropping steadily after each run (HR was obv. way higher during the runs due to heat). Think it lost 4 or 5 points on the run whereas on the bike I lost 2 points (measured with an 830). Don't think the 945 does have heat acclimatisation and just lowers Vo2max (which might also be correct, since your body will be working harder so performance is worse...)?
Currently all seems back to normal again however still with a 14point difference between bike and run Vo2max.
let's see what the labtest in 2 weeks will tell on these 2 metrics...
