Just play along. I use my Kickr indoors, not my crank based meter. I usually don't even have a meter on whatever bike is setup for indoor Kickr duty. For outdoors until I can buy a replacement, I need something I can do to try to get it a bit closer to reality. Most riding right now is outdoors.
I'm sick of having my crank meter read wildly different from my Kickr. By the indication of my on-road meter, I'd have a world class wind tunnel tested super crazy CdA and CRR. I know the reality. It takes me a good bit more watts than indicated to do what I do.
I've tested it against other meter (longer arm gravel bike meter) and my Kickr, and it is woefully different.
I've always just said "I know that it reads xx watts different, so calibrate your mind". Now, it's getting annoying because I realized since I do mostly outdoor riding now.........it's messing up my training metrics a good bit. Especially on threshold workouts where you're at 30w or more less and your TSS winds up being a lot less tossing your metrics.
I will just bite it and buy another or different meter, but in the current time for budget reasons I need some way I can trick the zero tare to be closer.
I'm thinking a known mass of some amount hanging on the pedal or something. I know it looks for a downward position to tare, so that's out.
If I could get it down to "hang x small mass" each time, I'd be OK with that for a couple months to get the money to buy another.
Thoughts on what to do? Not interested in a bunch of hater-ade being poured out here. Just want to get by using what I've got for a bit longer.
