the first thing to did you click on add trainer? If it is linked up and working you will see the power and speed change in step with the effort you are doing on the bike. I would say not to connect any other power meters this will screw things up. The sequence is normally, first get the perfpro ct bridge running and connected to your trainer, confirm it is working by spinning and looking at the perfpro display. Once this is confirmed the next thing is to go to the program and search for the ant+ FEC trainer., it will have the ant ID as seem on the perfpro CT screen upper right hand corner. Connect to that and you should have everything, do not connect anything else since you get cadence, speed and power all from the computrainer. If that does not work make certain that the CT bridge is the first thing you fire up
always and make sure that garmin is not running in the background and interfering with your ant stick. Hope that helps? I have not tried Rouvy but I have had it work with Sufferfest, trainer road, and Xert player all connecting as ant+ FEC.
did you follow this:
https://perfprostudio.com/....htm?page=Setup.html Good luck, let us know if you get it to work.
