Tom_hampton wrote:
Thank you. I was about to say the same thing.
Drives me nuts.
Three posts above all advising to buy treadmills with HP ratings FAR in excess of what is physically/electrically possible in a standard US home.
Unless you are plugging your TM into a dedicated 220V / 20A circuit, you aren't getting 4HP out of the damn thing.
You are absolutely right that a 5HP motor will not generate 5 horses on a typical circuit, which is why I suggested dedicated. Hell, mine would very easily pop the breaker on a 15A circuit, even if it was alone on that circuit.
What is ignored in the above calculations, is a motor rated at 2HP, will only put out 2HP before you are overloading the coils, and will run quite hot in the mean time. What you get with higher HP motors, is headroom to handle the spikes in demand, and yes, your house will provide extra power for a second (not quite a full second) to allow for those spikes. Plus, most homes will actually pull 120v, which on a dedicated 20A circuit will support 2.9HP output continuous before tripping the breaker, plus the treads have regulators inside that limit that draw. Now a Sole F80 will fit that bill (and it does recommend a dedicated 20A).
I have run on plenty of 2HP treads, and I usually get about .1miles before I have to just get off it's so jerky. There is a reason lots of commercial treads are 4HP+
I only responded to this thread because I am also a larger individual, and I know how we can destroy equipment that isn't up for the task, only suggesting commercial units because that is where I found the best value for what in my experience, I needed.
