Intermittent claudication?
I believe I have intermittent claudication. I'm an age group triathlete, able to swim and bike just fine. However, after running just a short distance (mile) I experience a painful tightness in both lower legs, below the calf, more towards the Achilles area. Although I have been diagnosed with PAD, and have had both femoral arteries reamed out, my vascular doctor thinks I have an orthopaedic issue, not a vascular one. If I stop and massage the areas, eventually I am able to run with little or no pain. This is why the doc believes the problem is orthopaedic. I do a lot of stretching of the area, and also use a hard (Piece of PVC pipe) as a foam roller. I still am able to do Escape From Alcatraz, being a longer effort. Right now sprints and Olympic distance races are out, as I can't go hard from beginning to end.
Any thoughts? I'm stuck on 257 triathlons, dating back to 1984, and would like to reach 300.
Re: Intermittent claudication? [cwienckowski] [ In reply to ]
Do a search on this forum of external iliac artery endofibrosis. You'll find a lot of good commentary.
Agree with Eileen, this sounds like it could be endofibrosis. Your run of the mill specialist may not know much about it in triathletes so you may need to seek out a specialist in this area. Unfortunately the management is rather invasive (as it sounds like you already have PAD these options may not even be suitable).
