Hi All,
I've recently picked up the orginal Tacx Neo and having a moment trying to understand the cassette installation instructions.
The cassette i'm installing is : SRAM PG1070 10 speed
Part 3 of the instructions state the following: Determine the needed connector based on the cassette. Its starts taking about 'pockets' (No pocket /With pocket)
At this stage i'm not sure if i should be using a 1mm or 2mm spacer.
Has anyone else installed the same cassette on this Taxc Neo - and what size spacer did you use?
Many Thanks
(i've added pictures of the cassette, trainer hub and instructions)
Many Thanks
