I have been using Zwift with iOS for a couple of years now. Is there any way in which segments of a training session can be repeated with iOS? For example, suppose I am running a training session and would like to repeat an interval (I know, WTF is wrong with you), is there any way of skipping back using iOS or perhaps the Companion App? Skipping forward through segments has been possible ever since I started using Zwift. I have not, however, been able to figure out how to skip backwards.
Re: Is it possible to repeat segments of a training session on Zwift with iOS? [Scott_B]
I think the only way to do what you're wanting is to go back in the menu and select the workout over again (without exiting first). Then it will start the workout over again and you can skip ahead to the interval you're looking for.
Re: Is it possible to repeat segments of a training session on Zwift with iOS? [Sean H]
I was afraid of that. It was worth an ask.
I think you are doing Zwift workouts? If so this probably isn't what you want to do, but I often do repeats on Zwift on KOMs and segments, like 3x(however long) up the Volcano KOM. So in this case I am picking a route with that climb, then descending, then doing a U-turn at the bottom/when I'm ready to go again, and I can add on an extra if I want, or do a little extra rest, or whatever. If you've never tried this, I recommend it, it's fun.
Re: Is it possible to repeat segments of a training session on Zwift with iOS? [brando]
Yes, I was referring to Zwift workouts. Hill repeats as part of a free ride is fun, kind of, and I do those types of sessions from time to time.
Custom workout, insert extra sets followed by the rest also, skip the extra sets using Z-companion app during the workout when you don't want to do them.
Re: Is it possible to repeat segments of a training session on Zwift with iOS? [burnthesheep]
That will work. Guess it's time to watch a video on how to create a custom workout.
If you use training peaks, just create the workout there, it's super easy. Zwift will automatically pull it in.
Thanks. I’ll give that a try.
