skyjuice wrote:
Thanks for the input. Now to make things longer, do I move the front end (arm rest) forward or do I move my saddle back? If I drop my arm rest down and saddle at the same time, what would be the difference from the current setup since the difference would be minimal?
I'm recommending you move the armrests down a LOT, and the saddle down just a little.
Moving the saddle down and a bit forward will help with your leg being too straight at the bottom of your pedal stroke.
Moving the armrests down a lot will make you much more aerodynamic for about the same amount of comfort. Having the armrests between 2-3 inches below the top of the saddle is a good place to start for good aerodynamics. (The goal is to get your back as flat as possible while still being comfortable.)
