xntrickly wrote:
Same question with me and my $%^box works wirelessly and the ports on the right side work just not the left side...
Unbelievable that these boxes aren't readily available !!
Advice greatly appreciated...
If you remove the cables and look into the port you may see the "pins" on the side not working are broken. This was my case.
They can be replaced by someone really good with a soldering iron.
If you take the case apart, you may be corrosion around the ports that are not working from sweat getting in. I suspect this too could be fixed.
