Should be fine. The main issue with plastic rim strips is if they are too narrow (not the case with your wheels) and slide to one side (since they are not adhesive), exposing part of a spoke hole.
The ultrasonic welded area around the valve hole is not a problem, since there is also thicker latex/butyl there on the tube.
If you plan on changing to a new rim strip, I'd recommend tape (ex. Stan's rim tape). Super light, and low profile (easier to install tires). That's an upgrade vs. a requirement to run latex.
ECMGN Therapy Silicon Valley: Depression, Neurocognitive problems, Dementias (Testing and Evaluation), Trauma and PTSD, Traumatic Brain Injury (TBI)
