I would be happy if you could point where that is written.
Only found this in the Ironman rules:
Professional Status Any athlete holding elite/ professional status from their ITU Member National Triathlon Federation or an IRONMAN Professional Membership (as verified by elite/ pro status of an athlete’s National Triathlon Federation) is prohibited from racing as an age group athlete in ANY sanctioned triathlon events anywhere in the world, where there is an elite/ pro wave, within the same calendar year.
Disqualification and potential sanction from WTC events, and forfeiture of any age group world championship qualifying slots may result for any athlete that has not adhered to this policy.
To be part of the elite field in an ITU event (Du or Tri) the athlete must be selected by the NF (which it ITU Member) which should be enough to ensure the athletes holds an elite/pro status, even if for that race only... Unless there is another rule, the rule above seems clear and does not refer if it was Du or Tri... doublea334 wrote:
Sean H wrote:
Duathlon and triathlon are completely separate. You can be pro in one and not the other, iirc
^This^ You can have your pro card in du and race amateur in tri. But I *think* if you’re pro in tri, you’re also pro in du. This is because duathletes are not as good as triathletes, and the pro du world gives them a chance to feel good about themselves.
_______________________________
The "Pocket Hercules" - jgrat
Technique sets the upper limit to where your fitness will take you...
