rruff wrote:
Tom_hampton wrote:
If you are going over bare 22.2 mm tubing then you need the 30mm stuff. The 40mm won't shrink enough to be tight.
Pretty sure I bought 30mm. It fit fine at first; seemed very tight, then loosened up with use. Tried heating it up a couple more times; same result. Finally got it so hot it burnt. Didn't help. Cut them off and tried again with friction tape under the heat shrink and that didn't help either. The outer grip was poor anyway when they got wet so I didn't see the point of pursuing it further.
I'm using Hed racket tape at the moment. Very thin and great grip. Cheap too.
I used to use racket tape (Gamma Grip 2). Great feel, but not as durable as I'd like. I've gone to using Silicone "rescue tape". It fuses to itself, but doesn't stick to the bar, so it's easy to remove. Cheap. Grippy. Lots of color options. Super thin. No cushion or damping though, just grip.
ECMGN Therapy Silicon Valley: Depression, Neurocognitive problems, Dementias (Testing and Evaluation), Trauma and PTSD, Traumatic Brain Injury (TBI)
