NAB777 wrote:
devashish_paul wrote:
lightheir wrote:
Just curious - For those that don't OWS before race - how much do you train in wetsuit and practice sighting?
I'm not a beginner, have been doing tri for 10 years now, but OWS access is definitely still a major problem for me, mainly due to scheduling but also because it's annoyingly far/trafficky for me to drive to.
I've found for myself that it's absolutely crucial for me to swim in my full sleeved wetsuit at least 3x prior to race day - the first sessions is always terrible due to early arm fatigue, but it goes away completely by the 3rd. (My wetsuit fits totally fine as well, I've tried a few, and the one I'm using definitely is not problematic for fit.)
I also have found that deliberate practicing of sighting in the pool (both with and without wetsuit) is really important for me to keep a good rhythm with swimming on race day. I don't do much sighting if practice if I'm 2 months+ out from race day, but I'm doing it every session, for a lot of the session the closer I get to race day and it also seems to make a huge difference.
Just kinda surprised it never gets discussed here, although I guess you don't have to worry about this type of prep much if you have regular access to OWS prior to race day which is obviously recommended over no-OWS.
You really don't need to practice sighting unless you are going to lead the race or lead your wave. Pythagoras is your friend. Everyone THINKS they do long detours but this is not true UNLESS you go really wide at buoys. Just put your head down and follow the bubbles in front of you and you will get to the finish line of the swim. Everytime you look up to sight you will lose time when your hips drop....that time loss is much worse than just keeping your head down and following bubbles of the swimmers in front of you.
As for the arm fatigue, I hear you, but it may just be because your wetsuit needs to be soaked after sitting around for a long time.
No, mate. Had I done that 2 weeks ago I would have followed the guy in front of me out to sea. There have been quite a few times that my sighting has enabled me to put ~30 seconds into guys who were ahead of me during the swim.
Quoting myself!!
I just went back & checked the result of the race I referenced above. We are talking about a deep water start, the race was 1200m, of which ~ 1100m was dead straight, parallel to shore, then we turned left & had about 100m to the finish line. Perfect, flat conditions.
The guy I was referring to kept drifting right (out to sea), I couldn't get ahead of him so at 300m, I actually stopped to let him go, and once I did that, I gradually pulled away from him. I put 40 seconds into the next place behind me, so if it was him, that's 40 seconds in about 900m - and this is someone I couldn't pass earlier on.
Point being, you shouldn't blindly follow the person in front of you.
