Tldr: 25.5mm external and 16mm internal width wheels. Should I go for 23c or 25c?
My 25c GP5000 measure in at 27.0mm on my 19mm internal wheels which are 28mm at the brake track (Enve 7.8). Its just below the 105% rule but someone, I think Aerocoach, tested the 25c corsa faster than a 23c. Based on BRRs measurements the corsa and GP5000 are sized very similarly, so I trust that's the best size for that wheel.
I'm a sucker for deep wheels, so I ordered a Knight 95 set during their holiday sale. They are advertised as 25.5mm at the brake track, 16mm internal and Knight recommends 25-28mm tires. I presume that's nominal, but not sure. Since the inner width is 3mm less than my current wheels, the 25c GP5000 should probably be around 25.5mm wide, which would be 100%. But a 23c would probably be over 110%.
Which tire size does the ST think tank recommend for these wheels?
Here's a pic of 23c and 25c GP4000 mounted on them, courtesy of tririg: https://www.tririg.com/...95_Review&num=10
