Shambolic wrote:
I tried with my 9070 derailleur but couldn't. You need a longer cage as the top pulley teeth in the cage start running against the cassette as you get to your 30.
Did you adjust the B screw? Maybe try the trick with putting the B screw in in reverse?
I'm running a Di2 9070 RD using an Ultegra 11-30, albeit in a 50T 1x setup, which takes chain length problems out of the equation. This is without the B screw put in in reverse - I might be able to get away with an 11-32 if I do that.
As alluded to above, frame hanger geometry can play into all of this.
