jtklein wrote:
Justin,
Thanks so much for the advice. I actually gave it a go this past weekend and had somewhat mixed results. I'm not sure my super concentrated bottles were correctly measured and on top of that, unless the BTA was empty, I had no idea how much to squeeze in. Any add'l specifics you could provide on how you make it work would be very much appreciated.
Also, pretty cool that you responded because I have seen most of your videos.
Thanks again,
Jeff
👋 Small triathlon world. :)
Yeah, I've got lines on my concentrated bottle in thirds, should have clarified that. So a little more detailed, I've found that concentrating more than about 1000 calories / 10 scoops in a bottle gets pretty goopy. 13 scoops would be... probably doable, but not ideal. So if you're going for many hours off of 3 total bottles, you could do something like: setting off with a BTA at 1x concentrate good for one hour, and a BTS bottle with 3 hours of nutrition concetrated. Once the BTA is empty, add 1/3 of your BTS bottle to it and top with water. Repeat the next two hours. So now you're getting 4 hours of nutrition out of two bottles, which will get you to SN at cutoff pace (or juuuuuust before it?) at 333 cals/hour. Could easily stretch another hour out of a 1000cal bottle if you're doing 250/hr or supplementing from the aids. I run an XLab Torpedo which holds 26oz, so if it's empty, you squirt in a third of your bottle of concentrate, and top with water, you're right in line with
the Tailwind recommended osmolarity. EDIT: Regarding "Unless the BTA was empty, didn't know how much to squeeze in..." Valid. I don't have a super specific answer to that, but for nutrition, I like to think more in terms of time than distance. So you know that each hour is going to be one BTA and one 1/3 of your bottle, for instance. This is where I think there's a lot of benefit running two BTA bottles (one concentrate, one water,) because then you're disconnected from the aid station timings.
Then at SN, you can either just take another concentrated bottle or have your concentrate bottle + a 1x to fill your BTA with right away. Protip, buy dollar bottled water for the bottles rather than using actual $10 water bottles for here since you'll have to toss them.
JustinDoesTriathlon Owner, FuelRodz Endurance.
