Hi guys my 808 hub broke...trying to repair it if you have one you want to get rid of. Thanks
Re: ISO ZIPP 808 rear hub (11 speed) [mcregal]
mcregal wrote:
Hi guys my 808 hub broke...trying to repair it if you have one you want to get rid of. ThanksDepending which wheel you have, Zipp might do that for you, as they had a recall on some of their hubs.
Hopefully you didn't get hurt.
Re: ISO ZIPP 808 rear hub (11 speed) [spudone]
Those were front hubs. I had that done.
If your hub isn't covered under warranty I'd suggest finding an local experienced wheel builder and have him lace a different brand hub into that 808. Personally I'd go with something like a DT240S hub as I have a custom road wheelset with those hubs and they've treated me well.
Re: ISO ZIPP 808 rear hub (11 speed) [loxx0050]
If it broke the flanges it will be the 20 spoke model.
Zipp are well aware of the issue but this has not been recalled because of the low failure rate and usually a rear failure will not put you on the bitumen.
Your first point of contact is Zipp, they may very well repair it for you.
They have done so may times in the past with wheels out of warranty.
Re: ISO ZIPP 808 rear hub (11 speed) [lyrrad]
Thanks guys. Zipp has stopped manufacturing the hub (2012 version) and won’t cover so I’m pretty much SOL. I contacted wheelbuilder in SoCal and it’s a little steep to repair. Just looking for other alternatives.
If you find the 9/10 speed (2009ish) version of the zipp 188 rear hub at the right price, you could also do the repair with that hub too, it is super easy to run that as an 11 speed hub via:
https://darkspeedworks.com/blog-11speed.htm
