trisomemari wrote:
nope, don't want to ride in that conditions :) not when it's raining from above, not through ankle-deep mud pools in the forest.
i hear what you are saying but not fully understand.
so with pop off and clean and rewax it's the full process
clean petroleum oil based lube with rust inhibitors but then mineral spirit to get rid of the "wet lube" and prepare for the waxing again
I cannot use the wd40 for cleaning and then wax without the mineral spirit process in between.
that's what I'm trying to get answered.
thanks for your help so far.
sorry if my answer was confusing.
If you have a waxed chain you are sort of committed to a certain path. if you break the path then you may not get the exact benefits of the hot wax approach.
So I say no you can not got degreaser (I assume that is what WD-40 cleaner is) without rinsing it off and then reapplying the wax. What you have done is simply remove the lube (wax) with the degreaser, then you added water , you can not truly dry the chain on the bike so there was residual water as well bare metal exposed to oxygen, therefore the outcome is rust.
I am not familiar with the WD-40 cleaner. if it is a citrus water soluble cleaner, then it should remove most things but then again???? Really from what I have seen waxing may not be the best option for really tough situations like wet dirty rides. Read what Adam says at Zero Friction.
So for the situation you were in with a dirty chain that had been waxed then a full clean down and hot waxing is the only true way back. When you do half way options you get results that prove it was not optimal such as rust. That simply shows that the bare metal was exposed to oxygen and well rust was the result.
Sometimes there is no short cut. If that is your desire you need a new lube approach which is why I suggested the so called wet lubes. They are a bit more tolerant of the wet muddy conditions.
Anytime you expose your chain to water it needs to be dried, and that is the purpose of the methanol. Mineral spirits does not help with that and actually will push the water into the harder to reach parts of a chain. water and mineral spirits do not mix. So you need to go cleaner/degreaser, if it is water based then water, then methanol (methyl hydrate) to remove the water then you can go to mineral spirits if you wish though I would not, and then to hot wax... otherwise you have a bare unlubed chain.
