Use P2 PowerTap as Single?
Hey all,
I want to use my p2 pedals for Zwift. But I realize it’s only showing “half” W because it’s actually dual sided.
Does anyone know a way to make it look like a single sided?
Thanks
Re: Use P2 PowerTap as Single? [sigmachi] [ In reply to ]
Short Answer: Either change the connection to ANT+ or remove a battery from one the pedals.
Long Answer: See https://www.dcrainmaker.com/...p-pedals-review.html. Basically each pedal has an independent Bluetooth channel, which allows them to provide things like L/R balance, but Zwift can't handle this situation. Powertap will say to use the Ant+ channel which provides total power but that requires an Ant+ dongle. The other solution is to remove the battery from one of the pedals as this automatically triggers the remaining P2 pedal to double its power. The pedals are communicating with one another and are designed to function as single sided power meters when a battery fails as a backup.
Re: Use P2 PowerTap as Single? [scott8888] [ In reply to ]
Awesomeness I’ll just remove one battery. Simple. Thanks mate
