source
https://otilloswimrun.com/rules/ 4 Equipment4.1 GENERAL ABOUT EQUIPMENT
4.1.1 All teams need to bring all their equipment from start to finish, if a team fail to bring all their equipment to the finish line they will be disqualified.
4.2 MANDATORY EQUIPMENT PER TEAM
4.2.1 Per team in World Series/Sprint/Experience
– 1 First aid pressure bandage, packed waterproof
– 1 Neoprene wetsuit per person suitable for the current water temperatures. If the water temperature is above 19 degrees Celsius you can choose to not race in a neoprene wetsuit. If you do so you must use a pull buoy.
– 1 Compass/Watch Compass
– 2 Whistles, 1 per person
– 2 Foldable cups/soft flasks or similar (not your swim cap) to drink from at the energy stations
4.2.2 Per person Solo Sprint/ Solo Experience
– 1 Neoprene wetsuit suitable for the current water temperatures. If the water temperature is above 19 degrees Celsius you can choose to not race in a neoprene wetsuit. If you do so you must use a pull buoy.
– 1 Whistle
– 1 Foldable cup/soft flask or similar (not your swim cap) to drink from at the energy stations
4.3 MANDATORY EQUIPMENT THAT THE ORGANISATION WILL SUPPLY
– Race bibs that must be worn visible all the time during the race
– Map
– Timing chip (lost or not returned timing chip will be charged 100 Euros or equivalent)
– Swimcaps that must be worn visible during all the swims
4.4 RECOMMENDED EQUIPMENT
4.4.1 Tether
4.4.2 Water bladder
4.5 EQUIPMENT CHECK BEFORE AND AFTER THE RACEBEFORE START AND AT THE FINISH LINE WE WILL RANDOMLY SELECT TEAMS FOR A CHECK OF THE MANDATORY EQUIPMENT. IF THE TEAMS ARE MISSING ANY OF THE EQUIPMENT REQUIRED, THEY WILL GET A 15 MINUTE TIME PENALTY PER ITEM.4.6 EQUIPMENT THAT IS NOT ALLOWED
4.6.1 The maximum size
pull buoy that you can have in any ÖTILLÖ race is 32 cm x 30 cm x 15 cm. If you want to have more than one
pull buoy the total size cannot exceed 32 cm x 30 cm x 15 cm.
4.6.2 No wetsuits can be modified with paint or color that washes off in the water. This will result in immediate disqualification.
4.6.3 Swim fins are NOT allowed if the fin is longer than 15 cm. Measurement is from the toe to the end of the fin.
