captainolek wrote:
Not sure I understand the difference between a clutched and a regular derailleur?
It has to do with the pivot for the cage (the part of the derailleur that holds the two pulley wheels).
When the rear derailleur is viewed from the bike's drive side, the cage is constantly trying to swing clockwise because of a spring within the derailleur. This is how the chain stays tensioned.
But how strong should the spring be? If the spring is putting only weak tension on the chain, the drivetrain will enjoy low friction and very light-action shifting, but it will also be prone to the chain bouncing around. If the spring is putting very high tension on the chain, the chain will be more stable, but drivetrain friction increases and shift quality gets worse.
Clutched derailleurs attempt to solve the problem by damping chain slap. In addition to the spring, there's a friction plate. A clutch within the pivot causes the friction plate to engage whenever the derailleur swings
counter-clockwise. So the cage can freely swing clockwise to wrap up loose chain (i.e. after shifting to a smaller cog), but the pivot has a lot of resistance when swinging counter-clockwise to let out chain (i.e. when shifting to a bigger cog).
Quote:
Also are there different derailleur references depending on whether you go 1x or 2x?
Yes.
SRAM's 1x derailleurs use a very large big offset between the cage pivot and the jockey pulley to manage the gap between the jockey wheel and the cassette. Basically, when you shift to a bigger cog, the cage rotates counter-clockwise (since it's having to release chain) which causes the jockey wheel to move downward. This is all well and good for a 1x system, but it gets quirky in 2x: shifting between chainrings will
also cause the cage to rotate, so front shifting ends up significantly affecting the behavior of the rear derailleur, which is obviously bad.
On SRAM's 2x derailleurs, the gap between jockey wheel and cogs is managed heavily by the angle of the derailleur's parallelogram. Shift to a bigger cog, and the parallelogram swings both inward
and downward, lowering the jockey wheel. This behavior is unaffected by front shifting, so these derailleurs work well in 2x drivetrains.
