Re: PowerTap clincher disc wheel? [MrTri123]
We can do it as a custom build if you send a message through the website below. Also if you already have the hub we can do a rebuild as well
AeroCoach UK
http://www.aero-coach.co.uk
AeroCoach UK
Wheelbuilder.
What do you mean by "disc"?
Disc brake compatible?
Or a solid wheel?
Or a solid wheel?
Re: PowerTap clincher disc wheel? [loxx0050]
This
Hed jet disc takes a regular spoked wheel, and can lace it to a powertap hub.
This has a standard aluminum brake track.
They then put a carbon airfoil over the wheel to make it a disc.
I've had no issues with mine.
If you need it serviced, you gotta send it in, but I got mine used, and with years of use, no problem.
Xavier wrote:
We can do it as a custom build if you send a message through the website below. Also if you already have the hub we can do a rebuild as wellThank you I sent a message via your site
