I think you're getting lost in emotion or something... As I said, I own and love the wheels. They are fast, brake well, are American made, great bang/$, and look nice. All I said was that HED is not one of the widest and listed some of the most popular wheels which are all wider no matter where you measure. But since we now have like 10 tangential discussions going on, here are your responses to those:
Anything "changing the argument" was added because of your tangential points.
You referenced something to make a point but it doesn't contain the info you claim. The 105% post says nothing about being at the widest part in any of the studies it references and at hose studies use wheels that bulge at most 1-2mm
HED themselves recommended 23 over 25 for aero, when tested with the GP4k.
Now that the GP5k has become 2 mm narrower, they recommend 25 and say 28 is slower, despite the fact that the measures well within 105% of the widest point on the fairing.
HED: "For all of our 25mm-wide Plus and Black rims, we recommend 23-28mm [labeled] tires. When inflated to normal pressure, the sizes go up 2-4mm depending on the tire model and pressure. For the really fast people, a 23mm tire (inflated to 26mm) is the best option." Since 23 rolls slower than 25, perhaps they are saying 23 is more aero on their wheels? Also, look at AeroCoach Zephyr/Titan data for another hint: the Jet+ 9 is nearly as fast as a titan with 23 tires but less close to a Zephyr (the slower wheel) with 25.
You mention aero performance. I agree that HED was and is one of the fastest. Has no implication on being behind on width for comfort. Narrow will always be fast.
You mention fit, which is just an excuse. All of the mentioned wheels are rim brake wheels and fit in 21st century frames with 21st century brake calipers.
You also mention weight, which is another excuse. The Jets are already heavy and a few mm of aluminum would add around 50g. Negligible.
1-2mm bulge in the Silca article is negligible in the sense that it does not extrapolate to aero properties of a 7mm bulge. 1-2mm difference in tire width makes a noticeable difference in comfort. The fact that you don't understand that 1-2mm can be a lot or not when it is measuring two different things makes me lose hope in this conversation.
